How NTT DATA navigates the European carbon regulation wave with whole-life LCA
Technology and Sustainability Consulting
Company size
200k+ employees worldwide
Madrid, Spain
Structural carbon cut
22% embodied carbon reduction
Modeling low-carbon concrete, recycled rebar, and CLT structure shows teams a path from 517 to 403 kg CO₂e/m² embodied carbon.
Decision-ready design
Scenario comparisons in minutes
Structural material trade-offs are compared live with clients, turning sustainability assessments into design recommendations while choices are still open.
Compliance-ready reporting
Audit-ready across EU and CTE
Whole-life assessments now meet EU Taxonomy, LEED Zero, and Spain's incoming CTE requirements, ahead of the 2028 EPBD mandate.
10:58
The challenge
NTT DATA's sustainability practice needed to respond to a wave of mandatory life cycle assessment (LCA) requirements across European building regulation. The team required a platform that could handle the full assessment workflow — from embodied carbon to operational carbon and offsetting — and deliver credible, auditable outputs to clients across certifications, EU Taxonomy, and Spain's draft Código Técnico de la Edificación.
The solution
NTT DATA adopted One Click LCA as the analytical backbone for its Green Engineering practice in Spain. The team uses One Click LCA's Materials Compass, Carbon Designer 3D, and Emissions and Removals tools to run life cycle assessments, model design alternatives, and quantify offsetting scenarios for clients across new construction and renovation projects.
NTT DATA now delivers whole-life carbon assessments — covering embodied carbon (A1–A5), operational carbon, and compensation scenarios — with the depth required by EU Taxonomy, Level(s), LEED Zero, and the incoming mandatory CTE requirements. Carbon Designer 3D enables rapid structural scenario comparisons, demonstrating reductions of up to 22% in embodied carbon through low-carbon concrete, recycled steel rebar, and cross-laminated timber (CLT) structural systems.
"Carbon Designer 3D lets us show a client, in minutes, what a 22% reduction in embodied carbon looks like when you move from conventional concrete to low-carbon mixes, recycled rebar, and CLT above grade. That speed of analysis is what turns a sustainability assessment into a design recommendation."
Daniel Corbi Technical Engineering Manager Green Transition & Sustainability Strategy NTT DATA
Carbon Designer 3D: reduce embodied carbon early in the design process with instant material insights
Learn more
experts
Practical insights on LCA, EPDs, regulations and low-carbon construction — straight to your inbox.
Explore more case studies
See how manufacturers, designers, and contractors reduce embodied carbon, scale LCAs, and meet compliance requirements.
Talk to our LCA software experts
Learn how One Click LCA can help you reduce embodied carbon in your projects, get compliant, and win more business.
