How Siemens Real Estate is scaling embodied carbon management across 60+ countries
Corporate Real Estate
Company size
~1000 employees
Munich, Germany
CARBON DECISIONS EARLIER
LCA before design begins
Life cycle assessment now informs projects before design begins, shaping the brief and procurement decisions early.
PORTFOLIO-WIDE BENCHMARKING
Compare carbon performance across projects
A connected Power BI dashboard gives a common view of embodied carbon performance across the global portfolio.
MANUAL DATA HANDLING
Less manual data handling
Structured BIM data, including material types and rebar content, enables automated quantity extraction and EPD matching.
1:21
The challenge
Managing embodied carbon across nearly 8 million m² in 60+ countries is a scaling challenge, not a measurement one. Siemens Real Estate faced three barriers: Life cycle assessments (LCA) happened too late, environmental data was fragmented across projects and systems, and sustainability sat alongside project decisions rather than inside them, making a consistent approach hard to apply across teams and regions.
The solution
Siemens Real Estate built a connected workflow around three principles: start LCA earlier, structure project data, and make carbon performance visible portfolio-wide. BIM supplies structured material quantities; One Click LCA delivers life cycle assessment and environmental product declaration (EPD) matching; Power BI brings results together for benchmarking. LCA moved to demand clarification, before design begins, so it can shape design and procurement decisions.
The result is a more systematic approach to embodied carbon management across Siemens Real Estate's global portfolio. Project teams can consider carbon earlier, compare performance across projects and regions, identify best practices, and bring carbon and cost information into procurement conversations, building LCA into the systems and decisions that shape projects from the start.
"Sustainability does not scale through ambition alone. Even if ambition matters, it scales through systems, data, and decisions."
Charlotte Miriel Sustainability-driven Project Leader Siemens Real Estate
BIM integrations: Automate LCAs & EPDs and save time with 20+ BIM & manufacturing integrations.
Learn more
experts
Practical insights on LCA, EPDs, regulations and low-carbon construction — straight to your inbox.
Explore more case studies
See how manufacturers, designers, and contractors reduce embodied carbon, scale LCAs, and meet compliance requirements.
Talk to our LCA software experts
Learn how One Click LCA can help you reduce embodied carbon in your projects, get compliant, and win more business.
