Listen to the article
Helsinki, Finland (June 03, 2025) — One Click LCA announces new AI-assisted upgrades to its platform — built to improve workflows, reduce the risk of quality issues, and scale carbon transparency. Designed to boost productivity and quality, the AI-assisted features help professionals and manufacturers ensure consistent quality, meet regulatory demands, and produce more accurate sustainability data at scale.
81% of manufacturers cite EPD complexity as a key barrier, while 37% of AEC professionals identify LCA automation as the top driver of time savings — according to One Click LCA’s 2025 Carbon Experts Report. The new AI-assisted upgrades from One Click LCA, delivered through the Power Pack, are built to support exactly that — and much more.
With the Power Pack, you can now streamline key tasks, from verification workflows and design modeling to report generation, helping teams deliver compliant LCAs and EPDs more easily and with greater confidence.
“Companies face increasing pressure to deliver accurate sustainability data at scale, under tighter regulations and scrutiny. One Click LCA's AI-assisted tools within the Power Pack are designed to scale sustainability — enabling verification workflows, flagging potential errors, and automating processes, improving data quality, and helping teams scale up their climate impact with confidence.”
- Panu Pasanen, CEO & Founder , One Click LCA
For product manufacturers —Improve quality, and scale EPD delivery
Environmental data must be both accurate and verifiable to avoid risk of greenwashing and to fulfil market requirements. AI-assisted checks help identify complex issues — including ensuring correct mass, energy, and carbon balances, as well as covering formal requirements — early in the process, and verification workflows help catch other issues. This reduces costly rework and avoids submitting erroneous data to verification.
With a focus on data quality, the Power Pack delivers three key benefits: scale your EPDs by streamlining EPD workflows for faster and more cost-efficient delivery, and produce consistent, branded EPD reports that meet global requirements. Each is outlined in more detail below.
1. Scale your EPD delivery — reduce cost, speed up compliance, and enable smarter selling
EPD submissions that are incomplete or inconsistent risk being rejected — resulting in costly delays, reputational risk, or lost opportunities. AI-supported feedback helps identify issues such as mass balance inconsistencies and biogenic carbon errors before submission. This reduces the likelihood of rework and improves overall process efficiency.
Learn how One Click LCA enabled Hydrotec to complete 29 EPDs in two months.
2. Streamline EPD workflows — consistent data, faster results, lower costs
Re-entering the same data across multiple product assessments is inefficient and prone to error. By centralizing, verifying, and locking down common inputs — including energy use, materials, waste, and packaging — manufacturers can apply consistent data across product lines. This approach supports faster, more accurate assessments and simplifies alignment with company-wide sustainability targets, especially in large or diversified portfolios.
Learn how Kiilto uses One Click LCA to automate EPDs, speed up calculations, and reduce reliance on external consultants.
3. Build trust with consistent, branded EPD reports — and meet global expectations
Verified EPDs and supporting documentation must not only meet standards like EN 15804 and ISO 14025 — they must also communicate clearly to clients, regulators, and internal stakeholders. Flexible reporting options make it easier to reflect your visual identity, ensure consistency, and tailor content to different markets. Multilingual templates help manufacturers meet diverse regulatory and client needs across regions, supporting certification, sales, and stakeholder engagement.
Need to scale EPD delivery while reducing cost and verification delays?
For AEC industry — drive better design and scale LCAs with consistent quality
The latest upgrades in the Power Pack help AEC companies produce high-quality LCAs, make informed design decisions early — even before all data is available — and communicate impacts to clients clearly and transparently. You can learn more about each of these in detail below.
1. Deliver consistent LCA results that your clients can trust
Produce high-quality life-cycle assessments with confidence. Built-in data checks and streamlined internal verification workflows help teams catch common issues early — such as missing quantities, duplicate entries, or incomplete data — before they impact results. This gives you greater confidence when submitting assessments for certification, client review, or regulatory approval.
Learn how Arcadis targets a 30% carbon reduction from baseline in an infrastructure project using One Click LCA.
2. Make informed early-phase decisions supported by generative AI optioneering
The most impactful decisions are made before design begins. Generative AI optioneering helps bridge that gap by creating a range of options for massing and feasibility study phases, allowing teams to compare and adjust them to fit project needs — and giving fast access to materials insights. This helps you make informed decisions at the most critical points of a project's lifetime.
Learn how to maximize value through early-stage carbon optioneering — top takeaways from Chapmanbdsp.
3. Communicate sustainability performance clearly and efficiently
Client and regulatory audiences expect carbon performance data to be transparent and accessible. Branded reporting options and pre-configured templates now make it easier to generate polished, consistent deliverables, reducing administrative time and ensuring sustainability performance is communicated with clarity and credibility.
Looking to deliver compliant LCAs faster and with fewer errors?
Power Pack helps companies scale, ensure compliance, and strengthen market position
Environmental requirements and stakeholder expectations continue to evolve. One Click LCA Power Pack helps your business keep pace with both current standards and future changes — from regional regulations to international reporting frameworks. It also supports market awareness by helping you track trends, demonstrate product sustainability more effectively, and strengthen your position in competitive bids.
With the Power Pack, you can identify compliance issues early, reduce delays and rework, and standardize data across sites and projects. It also helps you generate clear, accurate reports for clients and certification bodies, and make informed decisions earlier in the process. Designed to match how sustainability teams actually work, the Power Pack helps you deliver consistent, reliable results.
“Whether you're creating EPDs or delivering low-carbon buildings, the Power Pack helps you stay compliant, reduce risk, and lead with data you can trust. The Power Pack represents our commitment to powering the makers of a zero-carbon future.””
- Panu Pasanen, CEO & Founder, One Click LCA
Want to reduce LCA & EPD cost, streamline workflows, and stay ahead of compliance demands?
Keen to explore the AI automation features live?
The 2025 Summer Sustainability Summit will include a live demonstration and dedicated product update webinars featuring Power Pack.
- Register for the 2025 Summer Sustainability Summit
- Register for the latest product updates for construction professionals
- Register for the latest product updates for manufacturing & EPD professionals
About One Click LCA
Used in 170+ countries, One Click LCA is the leading end-to-end sustainability platform for construction and manufacturing. The AI-powered software decarbonizes and drives sustainability across the construction value chain with scientific, easy-to-use, automated life-cycle assessment (LCA) and environmental product declarations (EPDs) to calculate and reduce the environmental impacts of building, infrastructure, and renovation projects and products. The platform also allows assessment of circularity, life-cycle cost, and biodiversity. One Click LCA is used by blue-chip enterprises like AECOM, Arcadis, Foster+Partners, WSP, ArcelorMittal, Geberit, and Saint-Gobain, among others. It offers a unique global database with +310,000 LCA datasets; supports +80 standards and certifications, including LEED, BREEAM, GRESB, and other national regulations; and seamlessly integrates with +20 of the most widely used BIM software tools, including Autodesk Revit®, Tekla Structures®, and Bentley iTwin®. One Click LCA was founded in Helsinki, Finland in 2001, with a team of +200 people on all continents. Learn more at: oneclicklca.com
Muhammad Ali Saleem • Feb 20 2025
Abigail Mela • Feb 19 2025
Melina Zacharia • Feb 19 2025
