How Peutz Consult optimizes urban design projects and improves climate resilience with ENVI-met
Asha Ramachandran
Jul 30 2026 min read
Since 2018, the Air Pollutants and Climate team at Peutz Consult has used ENVI-met from One Click LCA in more than 120 projects, helping municipalities and developers design more climate-resilient urban environments through data-driven microclimate simulation.
Peutz Consult GmbH is part of the Peutz Group, an engineering consultancy network operating in the Netherlands, Germany, France, and Belgium. The company specializes in acoustics, building physics, environmental technology, sustainability, and façade engineering, supporting projects from individual buildings to urban districts
Engineering Consultancy & Urban Planning
Germany
Urban climate optimization
120+ projects improved through data-driven simulation
Since 2018, Peutz Consult has used ENVI-met across more than 120 projects, ranging from individual buildings to large-scale urban districts, helping clients design more comfortable and climate-resilient environments.
Sustainable urban development
Supporting climate resilience and DGNB certification
ENVI-met simulations help developers and municipalities evaluate heat stress, wind comfort, air quality, and green infrastructure performance while supporting sustainability frameworks such as DGNB certification.
4:19
Challenge
As cities face increasing urban heat island effects and stricter sustainability requirements, municipalities are increasingly requesting microclimate simulations as part of planning approvals. Peutz Consult needed a reliable way to evaluate thermal comfort, airflow, and environmental impacts during the design phase to help clients create climate-resilient developments while meeting regulatory expectations. The challenge was particularly significant when projects entered the planning process late, limiting opportunities for cost-effective optimization.
Solution
Peutz Consult adopted ENVI-met from One Click LCA to integrate microclimate analysis directly into urban planning workflows. Using the software, the team models buildings, vegetation, surface materials, weather conditions, and airflow patterns to assess how design decisions affect thermal comfort and environmental performance.
The consultancy follows a structured workflow that includes modelling existing conditions, simulating current and future scenarios, comparing design alternatives, and recommending optimizations such as improved building placement, ventilation corridors, additional vegetation, and surface material changes. ENVI-met also supports projects pursuing sustainability certifications such as DGNB by providing robust environmental performance data.
Since implementing ENVI-met, Peutz Consult has completed microclimate simulations for more than 120 projects. The software enables the team to quantify environmental impacts, visualize complex urban climate interactions, and support informed decision-making long before construction begins. As a result, clients and municipalities can confidently optimize developments for comfort, sustainability, and climate resilience.
"We chose ENVI-met because it's very user-friendly and allows for detailed modelling of the urban environment and climate, which is a very complex system"
Karina Zühlke Project Manager Peutz Consult GmbH
ENVI-met: Reduce heat stress & start building more livable urban spaces.
Learn more
Explore more case studies
See how manufacturers, designers, and contractors reduce embodied carbon, scale LCAs, and meet compliance requirements.
Start building more livable urban spaces today
Advance better urban living with the world's leading microclimate simulation software.
